help please for the last week when i stop and let my commander idle either in gear or park it will throw the check engine light on then after 15 seconds or so the engine will surge down once and throw the limp home mode on. if i shut it off then restart it and drive it runs fine and clears the light until i stop and let it idle again i have checked the code and its po 302 which is miss fire detected but it only ever miss fires when it goes into limp mode i read it does that when the ecm detects something it shuts down one injector which causes the miss fire but i cant seem to figure out what is causing the check engine light at idle i have checked the plugs, air filter, fuel pump, belt, oil, coolant, battery and electrical conections around the motor i am STUMPED please i hope someone can help!!!
