1 - 7 of 7 Posts
Factory UTV's Can-Am Maverick Max Ultimate UHMW Skid Plate Package has your Maverick Max covered! OEM skid plates simply do not satisfactorily protect the underside of your UTV under normal off road operation. Factory UTV has the answer with skid plates constructed from Ultra-High Molecular Weight (UHMW) plastic that is significantly lighter than aluminum. UHMW is tough, wear resistant plastic that combines an incredibly low coefficient of friction with outstanding impact strength, and will outwear carbon steel 10 to 1. Unlike aluminum, UHMW also has memory, meaning after a big impact hits aluminum will bend, gouge, and break while UHMW maintains it's original shape. FUTV’s skids and A-Arm Guards offer full protection for the undercarriage of your Maverick Max. These skid plates are very TOUGH! Protect your investment today! Remember, you save when you purchase the Ultimate Package
UHMW plastic is durable, light weight, and allows your UTV to slide over obstacles as opposed to denting or bending and stopping you on an obstacle like aluminum will do.
1 - 7 of 7 Posts
