21 - 29 of 29 Posts
Discussion Starter · #21 ·
Well hopefully your good to go for a while !!
Hopefully 馃憤 and thanks for the help.
Now I need to look at the shifting issue. It鈥檚 happened twice now at the very beginning of a ride then goes away. What is the one way bearing called? I need to research how to service it.
Discussion Starter · #22 ·
Found a video on this forum that I believe was made by you?
馃憤
It's called a onewsy bearing I guess. And yes it may have been one of mine . I would just replace the bearings with the double sealed bearings and be done. But I do have a service video. But it's more for general maintenance. Once it gets bad enough to hang the shifter it would be short lived after servicing it.
Discussion Starter · #24 ·
Thanks, I鈥檝e actually repacked truck and trailer bearings many times so I recognize the process. However I鈥檓 just going to replace them with new bearings like you suggested.
馃憤
Scott-
The bearings are just bearings. What makes it a one-way is the assembly that the bearings go into. As Ace stated, you'll want to replace them with aftermarket sealed, as the OEM are open bearings. Ace has posted a link to the service manual on this forum, if the video doesn't get you where you need to be. Forum member 'Wanker' sells the bearings if you need a source.
Automotive lighting Automotive tire Automotive design Font Rim
Hand Camera accessory Camera lens Automotive tire Digital camera
Edit: Here's a link to Wanker's site.
Between the two videos I got and the manual it should be a breeze . Acefire on YouTube for direct link to the videos . Or they are also on uatv-tech.com website with the bearings as well.
Discussion Starter · #28 ·
Dry cool stuff, thank you both!
21 - 29 of 29 Posts
