101 - 106 of 106 Posts
Discussion Starter #102
Im gonna wrap my exhaust next i think the placement of the exhaust right beside the cvt cover is stupid .. or at least put some sort of heat shielding
Discussion Starter #103
Also what is the top speed of these supposed to be i can get to 40mph pretty quick then it seems like it takes forever to climb after that
74 max ecm shuts the throttle body down at 74. But most can only get 68 to 72 mph . On flat ground .
Discussion Starter #105
Well after 250 miles and the last 100 or so being hard miles the belt is running fine... just need a new tie rod end now took my sister for a ride and caught a tree on a trail and busted the bolt off used a large Allen key in the tie rod end to the knuckle and limped home
The factory exhaust is actually a pipe inside a pipe (double walled) where it passes by the CVT and the CVT cover is plastic that doesn’t conduct heat. I doubt the exhaust contributes any heat to the belt especially with the high volume of fresh air passing through the CVT housing.
