Yes, very easy to do with very basic tools. Remove the seat and plastic side covers to access your belt cover. I have also found it easier to drop the bottom skid plate on mine to access the bottom bolts on the belt cover but have also removed it leaving it on. From what I recall takes an 8mm socket to remove outer cover bolts. What you WILL need that you likely don’t have is the clutch spreader tool that threads into the large clutch plate allowing belt to be easily removed and new one installed. Costs about $35.00 from BRP without it don’t even bother it’s absolutely needed.
