1 - 2 of 2 Posts
· Registered
Hello, I have a 2011 commander 1000 that I'm trying to replace ball joints and front wheel bearings on. I'm finding that the axle is seized into the right hub/ knuckle assembly. I've tried heat and a hub pulling device and heat and a hydraulic press to no avail. It almost looks as if axle splines have spun in the hub.
I'm seeing that hubs and knuckles are no longer available. Has anyone else experienced this and what was the fix?
Sent from my SM-S906U using Tapatalk
· Administrator
The hub and knuckle are still available. Just have to get them for a newer model. They had lots of 11 and 12 knuckles break so they updated them in 2013 by beefing then up where they were breaking. Heat should have done the trick Press and heat definitely shoukd do it.
1 - 2 of 2 Posts
