Toe out quicker cornering . Zero toe best tire wear. Toe in for stability low to high speed . No more than 1/4” in it out. Toe out is awesome for those tight quick turns but once you get above 40 mph in the straight always it tends to road walk and if you try to correct it you will actually make it worse . When toed out I would have to steer it back to center . When at zero it would recenter but was slow to center . Toed in I could let go of the steering wheel and it would return to center on its own and at a faster rate of speed . When I was racing I kept it 1/4” in more control and more predictable. Even at 1/4” in I seen no excessive tire wear over the course of 2500 miles . So my vote is still toe in .
