Additional switch panel
2K views 9 replies 3 participants last post by  acefire
#1 ·
I have a 2020 Commander Max Limited and I need to add additional switches to control lights and other accessories. The center panel has room for 6 switches which isn't enough. Just left of that panel and just right of the steering wheel is a panel that is empty behind but only has room for one switch. Is there a different panel that is made that could house 3 or maybe 4 additional switches in that space?
Thanks Kevin
#2 ·
Just take a dermel and a burr bit and cut you out some switch holes. There’s been several companies that made a switch holder but it bolted under that panel and was very hard on bouncing knees of longer legged people. I actually had cut mine out and mounted my two radio in that panel . So it can support a decent amount of weight .
#7 ·
I believe this is what you’re looking for
#9 ·
Yes but it don’t hit your knee and if you suck at cutting rectangle nobody will ever know!!
