1 - 11 of 11 Posts
My bike is still in the shop waiting on a new door so I don’t have anything to look at. I ordered a horn switch and was wondering if anyone Had a schematic for the 5 pins on the back of the switch. One should be power with the lights go on,one power coming in, one power going to horn ,than a ground. I just want to have everything I need to do this next weekend. Thanks for any help.
I’m not sure what’s behind where the switches go yet. I’m putting in my gps that I had with my older wheeler. Is the cigarette plug hot or is it on with the key. When you put the gps/ radio trim on do you have to swap the lower panel where the switches go as well as it came with one. I’m not sure if it’s different yet.
Cigarette is key on hot. There are a couple of plugs back there for key on hot power. I use the weatherpack plug as a relay trigger and back lighting source for my accessories, but I pull hot off of the battery to power my accessories, don’t overpower the built in acc circuits that way. I made some weather pack spltters too (not necessary but neat), pic below.
I’ve not added a gps but I did add a receiver to the same housing you bought. I ran a dedicated line from the battery for it.
And yes, you have to put the switches in the bottom part of the stereo/gps panel you bought. The panel piece it came with is just one piece.
All I’ll be adding is a gps which I could tap into the cigarette plug and a horn which is just a small alarm siren to alert my kids with a quick tap of the switch.
Maybe next year a stereo but I’ve spent enough for now on this thing. Ill have to fly you down when I’m ready.?
Those look right. I got mine on eBay too. The name of the seller I used is on the package in the picture I posted above. Of course they’re not necessary, you could use a t-tap connector, splice, etc., but weather pack connectors are more OEMish...
1 - 11 of 11 Posts
