Hello, new commander xt owner here.
Just did my break in oil changes at the 200m mark/13h. Bought all the XPS oil just for the first one to do it right. Front diff was easy, drained then cleaned plug and filled back up. Engine was just as easy drained then cleaned plug and filled up (2.1 q). Next was trans drained cleaned the plug and filled up little by little until its at max line per owners manual. After all that It runs the same and performs the same but now I am getting a new noise when driving it around and its noticeable when deaccelerating. It sounds like a power wheels car driving around and its coming from behind the cab. Just worried a bit since its a new noise since owning it. Doesn't seem to be getting any better as I thought the new 75w140 trans oil was just super thick. Searched the forums here to see if any relatable posts about were up but I seem to be the first. Blows my mind that just swapping fluids can cause this.
Any info or help with this is appreciated.
