I’ve got a 22 xtp max coming in a couple weeks (allegedly). Will this replacement bearing you mention fit the ‘22. They don’t list the 22 commander on the fitment list.This issue has been a issue sense 2017 when the x3 and mav trail came out. They all use the same bearing from factory. Satv and sandcraft have a solid mounted bearing replacement. I have installed them both and it does fix the issue. But no one on here seems to think that the aftermarket world can fix it with a far more superior bearing over the 30$ Toyota factory bearing.
2022 Commander XT-p. Ordered in October 2021 and received it June 2022. During dealer prep they noticed a vibration around 4k RPMs. They called CanAm and CanAm said it is a known issue with the drive shaft. Dealer is backed up and they finally received the drive shaft. It is being installed at the end of the month. Hopefully this will fix the issue. I don't understand how it can be a drive shaft when it is happening at 4k RPM in all gears.
Did they replace the drive shaft?Same here. Ordered mine last fall and got it in June. I asked about the shake before I picked it up because of what I read. They said they never heard of this issue. I got mine home, and sure enough it shakes. I made an appointment to get it fixed, waited 6 weeks and brought it in. When I get to the service counter they told me they attempted the brp fix on two other machines and they still shook. So they tell me they need to order need more parts and have no estimate on delivery, oh, and in the meanwhile “do not drive it”. That was a month ago. I’d be surprised if I drive it again before the snow flys.
No. They told me to wait until the bearings are in because the replacement shafts didn’t fix it.Did they replace the drive shaft?
Not sure they really know. I’m getting the feeling, from what I’ve read, they just keep throwing parts at these things until they get the right combo of parts by chance. Meanwhile- I keep making this payment on a machine I waited a year for and now cannot use.Sounds like I'm wasting my time getting the Shaft replaced.
When I brought my 22 mander xtp max right back in after picking it up new they said “the vibration won’t damage anything, go ahead and drive it until we get the new shaft in.”
Dealer ended up pulling both shafts and had them balanced and then filled the shaft cover with oil to absorb any remaining vibration. It got rid of ALL of the vibration.
Having said all of that, it doesn’t mean the vibration won’t ever come back. I’m no mechanic so I can’t say if my fix was a big bandaid or if it actually corrected it. Time will tell, I have rode it quite a bit and it’s a lot more fun to drive without that terrible rattle.
