1 - 6 of 6 Posts
I'm trying to hook up a light bar to the front of my ATV i have a 2020 Defender and can't seem to find an accessory hook-up i have the main power and ground under the front hood but no accessory bus bar. can anyone point me in the direction where i might find an accessory hook-up
Thanks!
Look under the middle of the dash, there should be a block, it might have a rubber boot on it, there should be three wires attached to it, One will be a ground (Black) The other two will be constant hot (red) and keyed on.
The dealer hooked mine up to the high beam factory switch. Works out well
2020 they moved the bus bar under the hood it's no longer under the dash ... the bar u found under the hood is the bus bar ur looking for
1 - 6 of 6 Posts
