It does get really hot in the cab especially when outside Temps are above 80 degrees. And 1900 hours is alot of hours I'd probably pass
Sent from my SM-S918U using Tapatalk
It's gotta be 1900 miles.Typical normal use on commander sxs is around 100 to 120 hrs every 1000 miles. Are you sure it’s got 1900 hrs? Normal use that would be 19000 miles . Everything would have been replaced 3 times at least .
