21 - 36 of 36 Posts
Discussion Starter #21
When I did portals, it came with stretched arms, it kept pulling them out of the rear dif every time I would get in any bind, had some longer ones made, and haven't had an issues since.
Im kinda new to this what do you mean by portals
Only people that run them are trailer queens mall crawlers and hard core mud guys. And they require extremely deep pockets .
Ouch lol, I was jst stating that I have stretched arms with my portals, and that did require a longer length custom axle to keep em in the rear dif, as the others had mentioned.
Discussion Starter #25
I use to have a toyota rock crawler, but I pretty much just want to go up the hills and have the clearance to do somewhat of the stuff Idone with it. so am i expecting to much out of the commander?
No not at all just gotta set it up for what you want to ride . I never ran a lift or anything bigger than 27” on my commander . Other than deep rutted mud holes it took me everywhere I wanted it to go. If you don’t sit the belly on the ground it won’t stop moving forward.
I've had og mavs, I jst sold my x3, the commander is the lowest to the ground, and required the most lift to clear a tire out of all of them, but if you don't mind throwing a few dollars and a lil bit of wrenching, the commander will treat you right jmo
Discussion Starter #28
I’m going to buy the rt lift today but this is only things worry’s me but I believe I can tie it up and maybe place an extra peace of rubber under it so it doesn’t rub.
66168
Must be something new going on. Have done several of the rt lifts never had one rub anywhere . What yr is that ?
When you put the lift on the new mount will be straight out from the factory shock bolt hole . Don’t think It will be anywhere near the radiator hose if that’s what you are worried about .
Discussion Starter #32
It’s a 2020. It’s in the same place the air intake hose is on the passenger side
Discussion Starter #34
I dont mind to spend the money I just dont want to spend money on stuff I wont be using later in the build
Clutches are money well spent, and a rt bracket lift is well spent, and can always be utilized along the way.
21 - 36 of 36 Posts
