1 - 20 of 37 Posts
Dps unit 500$
Front diff with torque locker 500$
Rear diff 350$
Rear drive shaft 50$ joints need replace
Seats 100$ ea
800cc engine 1500$
Gearbox 750$
Stm primary and secondary less than 300 miles 1500$
Everything is plus shipping.
Hey acefire talking to you last night on the popping axle anyhow that differs for a commander front one and if so how many miles are on it thanks
711 miles is what’s showing on the dash cluster with 300 ish on the torqlocker.
Discussion Starter #10
No I traded mine for a complete build ground up machine . But do to some bad geometry I have decided to part the machine out. All the parts are out of a 14 800 xt. Which was bought by the original builder .
I’m guessing that’ll work and 1000 I know on the oleanders we could swap them just not sure on the commander just want to be sure
The 400 outlander uses a different diff from the other outlanders .
But ole ace is bang on saying
Outlanders , commanders and OG Mavs all use the same crappy front diff . There is the standard speed and the QE . The QE came on models with power steering
Discussion Starter #16
It’s still in the machine. No hurry all the parts are still bolted down.
Discussion Starter #17
Pull your axle out stick something in there like a flat head screw driver bent on a 90° angle at the tip . Drop it in the grove. Pull straight out if it holds it’s not the groove if it jumps out of the groove it’s warn the edge off.
Guess I’m not doing that went out in the garage Forgot to put a new clip in it yesterday put it back together took it for a ride didn’t last long get on it tomorrow thanks
Ace fire I tried that today I couldn’t tell it seems worn Put a different clip in with an oring Under it went for a little ride stayed in but
1 - 20 of 37 Posts
