2014 Commander 1000 Limited, 1100 miles and getting the message for maintenance. What should I expect?
What is required at this time and approximately what is the cost?
Thanks ahead.
Most don’t go by the mainstream required message they just change all fluids and inspect everything every 100 hrs or 1000 miles.
After you change your oil and you other fluids if you change those, the pic below has instructions on how to turn the message off. It’s tricky to get it right and usually takes a few tries. It won’t work if your brake lights don’t work.
65980
I'm taking mine to the shop to do my 100hr service. $299 for it - all fluids/filters changed and full inspection. Peace of mind IMO. I don't mind changing oil/fluids but once a year to have a 'qualified' person look it over is good for me.
celiman-
When you put 'qualified' in quotation marks, the little voice in the back of your head should be telling you to do it yourself.;) I'm just kidding......sorta'.
