1 - 2 of 2 Posts
I have a 2013 outlander max 800
I’ve changed the ignition switch but I’m still not getting headlights winch or not charging in the headlight position on the key switch only
It will charge and the winch works in the other key position
Check the light relay. If it is bad, replace it. If it is good, leave it out and try it. The lights won't work with it out, but if everything else then works, there's a short in the light circuit.
1 - 2 of 2 Posts
