1 - 3 of 3 Posts
Hi, Guyz
I have a problem with my NEW CanAm Commander 1000x, from the first ride , its sound and looks like it was on 4x4, but it doesn't. The switch is in OFF position.
I took the commander to the BRP workshop and they put their scanner and everything figure OK!! But the Commander is LOCK (looks like and sound like engage ) .
What i can do, Please help me!
Flip the switch to on and test ride it and see if the 4x4 is engaged or not engaged. Then flip it to the off position and see if it engages or disengages. If you get no change. IE it is staying in 4x4 all the time or isn't engaging 4x4 at all you have a issue and you need to have them physically look at it and not just check the computer.
Before my 2012 x had hit 10 hours it didn't lock up the front diff a few times but after 10 hours it seemed to lock up and work just fine. So you may want to put a few (10+) hours on the machine and get thru the break in period and see if it sorts out.
1 - 3 of 3 Posts
