1 - 10 of 10 Posts
Hi guys i have a 2011 can am commander was riding last weekend when all of a sudden my cooling fan headlights and 4x4 stopped working ive checked fuses and relays all seem to be fine ive checked battery connections seem fine also follwed the harness best i could havnt seen anything out of ordinary just wondering if anyone else had the same issue with a solution thanks 馃憤
Did you check the little fuse box up and to the left of the big fuse box?
Had the exact same problem with my 2014 last month. Headlight hi-lo beam toggle switch was bad, kept blowing 5a fuse. Winch wasn't working either. Changed switch, problem solved!
1 - 10 of 10 Posts
