BRP enters the side-by-side market with the Can-Am® Commander™ 1000, Commander 1000 XT™ and the Commander 1000 X™. Can-Am engineers and designers worked hard to create a side-by-side vehicle that sets a new industry benchmark in performance, handling, comfort and convenience.
Each model features the most powerful* engine in the side-by-side industry with the 85 HP Rotax® 1000 EFI V-Twin powerplant and brings a host of innovative features to the industry, like: Throttle Control system (iTC™), a 2-inch diameter, high-strength steel cage that is ROPS Independent (TTI) rear suspension design, removable, free-standing full-bolster driver and that requires no tools to adjust; quick-attach side nets and more. The Commander 1000 line also a strong Can-Am DNA presence.
2011 Can-Am Commander 1000 Family Highlights
» 85 HP Rotax 1000 EFI V-Twin engine
» Industry-leading fuel mileage
» Dual-level cargo box
» Intelligent Throttle Control (iTC)
» Visco-Lok front differential
» TTI rear suspension
» Double A-arm front suspension with dive-control geometry
» 2-inch diameter, high strength steel, ROPS-approved cage
» 1,928 cubic inches (31.6 litres) cockpit storage
» 240-watt lighting
» Quick-attach side nets
» 10-gallon (38 litres) gas tank
» Normal & Performance D.E.S.S.™ Keys (w/ an optional third work key)
» 3-point seatbelts with anti-cinch
» 11-inch (35 cm) of total ground clearance
» 214mm disc brakes with twin-piston calipers
» 26-inch Carlisle‡ Black Rock radial tires on 12” wheels (base model)
» 1,500 lbs. (680 kg) towing capacity
» 2-inch rear hitch receiver
» Comfort seats with sit-in fore / aft driver adjustment
» Adjustable-tilt steering
» Passenger handhold and grab bar
» Dual cup holders
» 650-watt magneto
» Easy-to-use maintenance centre
» Base model available in yellow
» 240-watt lighting
» Dual cup holders
» 650-watt magneto
Can-Am Commander 1000 XT Package Includes
» 4,000-pound winch
» 26-inch Maxxis‡ Bighorn 2.0 tires
» 14-inch Cast aluminum wheels
» Analog/digital gauge
» Heavy-duty front bumper
» Rugged bed rails
» Mud guards
» Leather steering wheel
» Available in Red, Yellow and an optional industry-exclusive NEXT‡ G-1 Vista camouflage.
Can-Am Commander 1000 X Package Includes» 26-inch Maxxis‡ Bighorn 2.0 tires
» Rugged bed rails
» Mud guards
» Fully adjustable front and rear Fox Racing Shox‡ HPG piggyback shocks
» Front sway bar
» 12-inch aluminum beadlock wheels
» 26-inch Maxxis Bighorn 2.0 tires
» Rock sliders
» X-package seat trim and graphics
» Available in black with yellow accents
Can-Am Commander 1000 Family Features and Benefits Rotax® 1000 V-Twin engine // Newly developed for this project, the Rotax 1000 80º V-twin is the powerful side-by-side engine in the industry* with 85 HP. The liquid-cooled, single overhead cam plant features four valves per cylinder and is fed by a 54mm Bosch‡ throttle body and two VDO fuel injectors. The sophisticated electronic fuel injection system automatically keeps the at its peak, regardless of temperature or altitude.» Front sway bar
» Rock sliders
Industry-leading fuel milage // Not only is the Rotax 1000 V-Twin EFI engine the most powerful engine in the side-by-side industry, it also has class-leading fuel mileage. Meaning you can trails longer.
Intelligent Throttle Control (iTC) // New throttle-by-wire system that works in conjunction with the 54mm Bosch‡ throttle body to product smooth throttle delivery even if one’s foot is bouncing the terrain. The iTC system detects unwanted bounces and filters the input, resulting in more especially at low speed. This system also reduces the number of moving parts in the vehicle; hasno cables to adjust, lubricate, or replace; and the system has an increased life span.
Dual-level™ cargo box // BRP’s Can-Am Commander 1000 features the industry’s first cargo box with two levels separated by a removable, water-resistant panel. It offers the possibility to and a lower bed with an independent tailgate. Carrying capacity of the box is 600 lbs. total capacity. (400 lbs. upper, 200 lbs. lower) and has the most volume capacity in the market. The tilt-assist dumpbox can be easily activated from both sides. The Commander’s box is constructed and anti-dent composite. Easily removable tail gates (upper and lower), no-tools needed with latch, truck-like, upper and lower tail gate with four tie down hooks located in corners. There integrated vertical grooves for plywood dividers and the Can-Am Commander also comes with an trunk lock as an accessory to secure the lower level.
Visco-Lok front differential // Progressively transfers power from a slipping front wheel to the gripping one – automatically with no buttons to push or levers to pull. Plus, there’s no wheel driveline wind-up so the system is totally transparent to the driver and extremely easy to
up to 100% with no rev or speed limiter. The Can-Am Commander is the only side-by-side vehicle industry with a progressively locking front differential requiring no additional switches to the locking mechanism. Simply put it in four-wheel drive and ride, the differential will begin
when you need it allowing you to steer easily in challenging conditions.
Torsional Trailing arm Independent (TTI) rear suspension // Inspired from the world of toplevel, off-road trophy trucks, this trailing arm design provides excellent control and stability, in rough terrain by eliminating scrub. Wheels move rearward as they move up and down producing a smoother ride than the competition, and the side-by-side does not waver down the trail. Plus, up to 75 percent fewer parts than competitive designs and significantly decreases tire wear. The end features 10 inches (25 cm) of travel and the largest diameter rear, five-way
shocks in the industry 36mm (1.4 inches) for overall durability and better resistance to fading.
Double A-arms front suspension with dive-control geometry // Double A-arm suspension design features up front dive-control geometry, which works to eliminate diving under heavy rough terrain. By controlling vehicle dive, the Can-Am Commander handling is more precise in all and terrain types. The front end features 10 inches of travel (25 cm) and the largest diameter five-way preload-adjustable gas shocks in the industry (36mm or 1.4 inches) for overall better resistance to fading.
2-inch diameter, high strength steel, ROPS-approved cage // The Can-Am Commander familyof side-by-side vehicles feature a two-inch-diameter, high-strength steel cage that is fully using the Roll-over Protective Structures (ROPS) industry standard.
1,928 cubic inches (31.6 litres) cockpit storage // The Can-Am Commander 1000 family features the most cockpit storage in the industry with almost 2,000 cubic inches of storage in three compartments. The glove box features 1,050 cubic inches of storage that can be divided into
sections. In the center console, easily accessible by both the driver and passenger, features 79 inches. Finally, there are 799 cubic inches of storage under the fully adjustable driver’s seat.
26-inch Carlisle Black Rock radial tires on 12-inch wheels (base model) // The base model of BRP’s Can-Am Commander 1000 line features rugged Carlisle Black Rock radial tires mounted on 12-inch wheels. This six-ply radial tire is designed specifically for side-by-side applications.
240-watt lighting system // The Can-Am Commander 1000 family of side-by-side vehicles features the industry’s best lighting system at 240 watts. Dual left and right automotive-style 120 watts in low beam and 240 watts in high-beam mode.
Quick-attach side nets // Side nets on both the passenger and driver side are easy to open and with one-hand and one-click. It was specifically designed to keep a clear field of vision for passenger.
10-gallon (38 litres) gas tank // Largest gas tank in the side-by-side industry for maximum out on the trail and at the work site. Total capacity is 11 percent more than the nearest competitor.
NORMAL & Performance D.E.S.S. Keys (w/ an optional third work key) // The industry’s first standard anti-theft device. Electronic code in key must match code in ECU to start. The family comes with two different keys. One is the normal key, which limits top speed to 44mph (70 km/h). The second key is the performance key which has no limitation on speed or power. An key is available for purchase and limits top speed to 25 mph (40 km/h) for use on work sites.
3-point seatbelts with anti-cinch // Three-point seatbelt features anti-cinch design for added comfort. Speed limitation feature if driver’s seatbelt is not fastened properly.
11 inches of total ground clearance // 11 inches (35cm) of total ground clearance for maximum performance in challenging terrain. Sag is built into the suspension, allowing the system to travel “sweet spot”.
214mm disc brakes with twin-piston calipers // Front and rear outboard disc brakes with 214mm discs and twin-piston calipers.
1,500 lbs (680 kg) towing capacity // The Can-Am Commander 1000 family features 1,500 lbs. of towing capacity allowing the user to tow heavy loads.
2-inch rear hitch receiver // The rear of the vehicle features a standard two-inch hitch allowing for a standard vehicle towing bar and ball to be used with the Commander 1000 family
Comfort seats with sit-in fore / aft driver adjustment // Both driver and passenger sit in seats designed to give maximum comfort and refine the side-by-side experience. Full bolster seats and shoulder support, and provide comfort in aggressive riding situations. Both seats are
to allow easy entry and exit of the machine. The driver seat is also adjustable fore and aft need of tools; it is an automotive-style adjustment for 6.3 inches (16 cm) of total adjustment.
Removable, free-standing seats // Both seats are removable and free-standing allowing them to be used outside the vehicle. Set them up around the campfire at the end of a long day of riding the evening in comfort.
Adjustable tilt steering // The steering wheel is adjustable for a total range of 30.5 degrees the need of tools. The gauge also pivots with the steering wheel for maximum visibility.
Passenger handhold and grab bar // Ergonomically designed passenger handholds are located immediately in front of the passenger and to their left-hand side. The passenger grab bar in seat features ergonomically correct bends for multiple and comfortable hand positions. The
grip bar on the center console provides the passenger an additional handhold located in a and comfortable position when required.
Dual cup holders // Two cup holders in the center console feature rubber flaps for off-road use.
650-watt magneto // The Commander 1000 has the largest magneto in the industry, a full more than its nearest competitor. This means the electrical system can dedicate up to 300 free power accessories like extra lighting, GPS systems, radios, speakers and more.
Easy-to-use maintenance centre // Easily accessible and out of the elements under the hood, a centralized maintenance area allows access to the airbox, radiator and coolant overflow. Fuses are also easily accessible.
Base color option // The Can-Am Commander 1000 base model is available in a signature yellow color.
