21 - 23 of 23 Posts
· Registered
Will it not go into gear with the motor shut off or just when it is running. If it will go into gear with the motor shut off then you have a clutch problem, if it will not go into gear with the motor running then it sounds like you have a gear set that may be out of time or a bent shifter fork. Have you rocked it while trying to shift it. And can you get it in neutral?
Yes it won't into gear when when shut off goes in perfect
21 - 23 of 23 Posts
